Unable to RDP to work computer (Dlink DSL-3782)
I have been trying for the past day to RDP to my work computer.
After research and different attempts, i've been told there is no way around it with this router?
Is this true?
And help would be greatly appreciated, is there anything i can do?
Thank you
have you turned off scam protection?
If you go to my account, you can turn this off there.
To do so:
1 Log in to MyAccount
2 Select My Services
3 Select View HomeSafe settings
4 Select OFF and confirm when you see the pop-up window
You may also need to disable any pop up blocker you may have installed
if this does not work you are in the staff's queue for a response.
For a quicker reply can you please ensure you have your personal information up to date in your profile. Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
Thank you
Good luck.
Hi Newbold2in1,
How are you getting on?
