Unstable connection
60 REPLIES 60
Hi Folks
   First off i couldnt log in with my usual account ,I'm not able to change the pasword .Internet is on off yoyo style. Could some one PM me to get my other account back and i can also sort which line is in need of attention .
They said it couldn't be fixed ...dont worry ,when I'm done it will be that bad NO ONE WILL!!!
Hi russtick1
Apologies for this.
Please can you send me a Private Message to confirm your Community Username.
Hi russtick1,
What actually happens when you try to log in with your old username, do you get and error message?
Hi Chris
   yes the old pasword had 3 letters the same so it wont now accept it and i have changed my email .well is expired was an old freeserve address.so im stuck.
The broad band connection is on and off too loud_crying_face
Hi russtick1,
OK, thanks, can you complete your Community Profile and we'll take a look at your dropping connection
Filled in
OK, thanks,
Line test is picking up potential issue and show reconnections
How many telephone sockets do you have? What other devices do you have connected in addition to your router?
Does your master socket have a Test Socket?
Just one socket (master) which has test socket under cover one router no phone ,however I suspect it will be the line ,possible tree damage(usually is) as we live in the sticks
Are you experiencing any problems with your telephone service such as noise on the line?
Yeah a crackly line on wired phone ,however it's not usually plugged in its just the router
Could you check if you still hear the crackle with just the telephone connected (router disconnected)
Will do when I get back cheers
Tried the wired phone and no crackle at the moment just high pitch hissing
Just to confirm, you could hear the hiss with just the telephone connected (router disconnected) to the test socket?
Yes thats right ,its not fully quietening.
OK, thanks. I've passed this over to our network team for further investigation. Can you bump the thread tomorrow and we'll check for updates
Hi Chris
   Back up to the top for an update
Hi russtick1, I've sent a chaser to ask for an update for you. I'll post back once I get a reply for you.
Hi All
   Looks like the router firmware has been changed but the connection is still dropping
