Hi Sean0207
Sorry for the delay.
I have checked your sync speed and it is showing as
Sync Status In Sync
Downstream Speed = 55.2 (MBPS)
Upstream Speed = 20.0 (MBPS)
Are you running wired speed tests?
Hi Sean0207
I'm really sorry for the delay.
I can see that the line is still in sync at 55.2mb. How has the connection/speed been since your last post?
Hi Sean
I'm just sending you a Private Message to confirm some details so we can check the predicted speed range for your line.
Hi Sean,
Thanks for answering the security questions, Line test is clear and router is currently in sync at 55.2Mbps. Are you experiencing any problems with your telephone service, any noise on the line?
