Upgrade to Fibre 65
Maxime-13
I upgraded a few days ago to Fibre 65 but havent recieved the new router what should i do as my current taltalk router is doggy and been dropped a few times?
Skynet_TX
Hi @Maxime-13,
If the router you already have supports Fibre then you may well not automatically get a new one when you upgrade.
The staff here will be able to offer more advice, as to whether they can provide a new one for you, or if you would need to buy a new one if your current one has been damaged due to being dropped.
Then they will hopefully be able to respond to this post within a working day or two.
OCE_Chris
Hi Maxime-13,
As Skynet_TX has said, you won't automatically be sent a new router when upgrading to fibre if your current router is compatible.
If you're experiencing problems with your service can you please update your community profile to include your:
  • Name
  • Telephone number
  • Alternative contact number
