Upgrade to faster fibre speed boost
Hi Bossblue
Please let us know once this router is connected and we can run a further line test.
Hello Debbie,
new router connected in test socket
i got 50.6 mbps down
18.3 mbps up
thats on wireless, much the same on ethernet
thanks
Hi Bossblue,
Thanks for the update. The line test is still detecting a potential fault. Can you confirm if you're also using all the new cables and microfilter that came with the router and if the router is still connected at the test socket? We can then pass this over to our Network Team for further investigation.
Hello Michelle,
yes all connected as you asked and still in test socket
thanks
Hi Bossblue
This fault is under investigation with our Network Team and I will post back on this thread as soon as I receive further information.
Hi Bossblue
This fault has been escalated to a BT Openreach line engineer for investigation and we should receive further updates within the next 48hrs.
openreach engineer came this afternoon
has checked everything and I am getting best possible speed available
i would appreciate if you can tell openreach, he was very polite and friendly, explained everything in detail and was very thorough and knowledgeable
also many thanks to you for all your help
thankyou
Hi Bossblue
Thanks for keeping us updated. I will pass on your feedback.
