Upgrading to fibre
13 REPLIES 13
Sanderh
Hi, myself and my partner are working from home and the internet is so slow. So we ran a service check and showed we are using too many video streaming items and suggested we move to fibre. I clicked upgrade and my account is now showing that i am on fibre but our internet is still really slow.
how long does it take for Fibre to take affect?
we have turned off all other devices or put them on aeroplane mode to help.
thanks!
Divsec
Hi @Sanderh welcome to the community your post has been flagged for assistance and you should hear during the day. Your sync rate will be a good indicator Check your sync speed .
Then try once a 30 minute router reboot, leave the router switched of for 30 minutes.
The team here will also check your line for any faults.
OCE_Michelle
Hi Sanderh,
Thanks for your post and I'll take a look now. I've run a test on the line which has detected a possible voice fault. Could I just confirm, are you experiencing any issues with the voice service such as no dial tone or noise on the line?
Sanderh
Thank you! I ran the test and its showing as 3.5 mbs and also turned the router off for half an hr but no change.
OCE_Michelle
Hi Sanderh,
Thanks for confirming. Did you see my last message about the voice service?
Sanderh
Hi, sorry missed that! No we don’t have a landline phone so i can’t test it unfortunately @OCE_Michelle
anything else i can do?
ta
OCE_Chris
Hi Sanderh,
Line tests are showing a potential telephone fault so I've raised this to BT Openreach as a non-appointed task. We should receive an update within 72 hours so if you don't hear anything beforehand can you bump the thread on Monday and we'll check for updates
Sanderh
Thank you @OCE_Chris !
Sanderh
Hi @OCE_Chris just to say the internet light is now showing up red in the router and we can’t get on it at all. 😞
OCE_Debbie
Hi Sanderh
Apologies for the delay.
This fault is still under investigation with the line engineer, we have no further updates at present.
Sanderh
Thanks @OCE_Debbie
OCE_Debbie
Hi Sanderh
If you post back here tomorrow then I will check this again with Openreach. Apologies again for the delays.
Sanderh
Morning @OCE_Debbie still no change this morning. Can barely operate any devices so had to use the 4g on our phones.
OCE_Debbie
Hi Sanderh
The notes advise that the engineer tried to call you but was unable to make contact. The engineer completed work on the line to resolve this fault (yesterday)
Are you still experiencing this fault?
