VDSL Settings for TalkTalk Fibre with non TT router
18 REPLIES 18
StefanoC
Wizz Kid
An OCE answering would be very much appreciated.
II'm looking to buy a third party ADSL/VDSL modem router to replace my TT super router. Probably a TP Link Archer VR900.
For ADSL connections TT publish the necessary settings however for Fibre VDSL I see no such settings. There are many articles and forum posts on the internet with various suggestions on how to set up but I don't see anything definitive.
Please TT can we we have the necessary settings for VDSL listed like you have done for ADSL connections?
Hi StefanoC
For the username - phone number@tt and password, although this should not be needed.  You should not have to set things like vpi / vci, but for fibre, the MTU is usually 1500 although this should be automatic.
When you  select VDSL as the connection type in the router, this should be all automatically set
What information is the router asking for when trying to set it up?
StefanoC
Wizz Kid
Hi Debbie
Ive not bought the modem router yet because I wanted to be sure I could get the correct settings. I'm looking at the TP Link Archer VR900 or VR2600.
Just to be clear, if I select TT as my provider in the setup menu then setup should be automatic but if not username is my telephone number@talktalk.net and the password would be Password?
Hi StefanoC
The settings will be automatic, if the router asks for username details then put in number@tt and password as 123456.  We use network level authentication so the details are not required, just the router expects them.
charlesb224
Wise Owl
TalkTalk Fibre for Residential customers does not utilise login information.  so no username or password required.  Just setup as IPoE or Dynamic or DHCP or automatic IP
HTH
StefanoC
Wizz Kid
Thanks to both of you for the advice.
Hi Stefano,
Please let us know if you need any further assitance
StefanoC
Wizz Kid
Hi Chris
I've not purchased the new modem router yet so haven't tested but thats all the help I need for now thanks.
Stef
PAROMITA
Hi ,
I was reading your helpful tips.
I have today switched to TT Fibre from normal broadband.So, the connection is OK with the TT router but the router is weak,
How would I change to a TP LINK AC1600 V1-Router which I already have- as last time, TPLink recognised the ADSL connection automatically .A friend said I need a PPPOE username and password to establish a VDSL link .How do I get this.I can connect to the VDSL net via the TT Router.Please help.Thanks.
StefanoC
Wizz Kid
Hi Paromita
I haven't actually gone ahead and bought a new modem router yet so I'm still using the TalkTalk supplied one. All I can advise you to do is follow the suggestions in this thread. From what people seem to be saying you shouldn't need a username and password for a vdsl connection.
Sorry I can't be of more help.
nrushforth
Chat Champion
I have the TP-Link AC1600 modem/router V1 as you do. I recently moved to fibre. I did a factory reset on the router and it connected first time after selecting TalkTalk VDSL as the DSL connectoin type in the Quick Setup wizard.
You may already be connected using this router, but if not, I hope this helps.
StefanoC
Wizz Kid
Hi. Thanks for taking the time to post. I never did get around to changing router so I’m still using the one provided by TalkTalk.
John_studley
I am a TT Fibre customer and I have just purchased a Technicolor TG789vav v2 voip router - I am having problems running ADSL under PPP and have had to use DHCP - any suggestions - John
StefanoC
Wizz Kid
Hi John
Sorry, I'm not that technical. Can't help you.
Chalkiejim
Problem Solver
If you are using a fibre connection, you should be using VDSL  and not ADSL.
StefanoC
Wizz Kid
Yes, sorry I missed that. Fibre requires VDSL.
Just installed a TP Link Archer VR2800 modem router and so far very impressed. Installation was easy. Just pick TalkTalk from the provider drop down list and all settings were self installed.
Chalkiejim
Problem Solver
I have the NETGEAR D6400. Had to do the same with that.
-npr-
This is how I configured my ZyXel VMG8924-B10A for Talktalk fibre (VDSL)
Main settings
Type: ADSL/VDSL over PTM
Encapsulation: IPoE
NO username or password required
VLAN
802.1p:  0
802.1q:  101
MTU Size:  1500
dkingpes
hi there guys was wondering which are the best settings and instructions to set up talktalk router dlink 3782 with the netduma so i can get the best connection for ps4 pro and pes 2019 peer to peer game.
im using vdsl and dynamic connection
does any one know the how to correctly use bridge mode?
or is there any better viable options to set up
thanks in advanced all responeses are welcome
