VDSL2 slower since I moved closer to the exchange
j0nbinnie
I used to live 1 mile from the exchange. I recently moved house, to 0.5 miles from the exchange. But my internet speed has halved! This is becuase my Fibre cabinet is closer to my old house, and now further away from my new house :-( Can TalkTalk move my VDSL2 to connect to a closer cabinet or directly to the exchange?
Jon
xDSL
ModeVDSL2
Traffic TypePTM
StatusUp
Link Power StateL0
 DownstreamUpstream
Line Coding (Trellis)OnOn
SNR Margin (dB)11.76.2
Attenuation (dB)27.40.0
Output Power (dBm)9.97.3
Attainable Rate (Kbps)276446287
Rate (Kbps)150006197
B (# of bytes in Mux Data Frame)47194
M (# of Mux Data Frames in an RS codeword)11
T (# of Mux Data Frames in an OH sub-frame)415
R (# of redundancy bytes in the RS codeword)1616
S (# of data symbols over which the RS code word spans)0.10161.0000
L (# of bits transmitted in each data symbol)50401688
D (interleaver depth)6371
I (interleaver block size in bytes)64211
N (RS codeword size)64211
Delay (msec)160
INP (DMT symbol)8.000.00
OH Frames72233432763603
OH Frame Errors30
RS Words1776903965863477
RS Correctable Errors3569122317
RS Uncorrectable Errors70
HEC Errors60
OCD Errors00
LCD Errors00
Total Cells13068692710
Data Cells4365546030
Bit Errors00
Total ES1385
Total SES02
Total UAS241682799
martswain
Probably not.
The cabinet your are connected to will provide services to defined properties and unless a new cabinet is installed for extra capacity AND OPEN REACH decide to move you, then you are stuck with what you have.
Martin
j0nbinnie
Thanks. Is there a way of requesting cabinet moves?
Hi j0nbinnie,
Your sync speed is outside of your predicted range. Do you know that there's a nearer cabinet to your home than the one that you're connected too?
j0nbinnie
Not sure there is a brown cabinet on the street but I don't know if it's fttc. The exchange is closer (under 0.5 mile) than the fttc cabinet!
Hi j0nbinnie,
Your speed is outside the predicted range so we can try to improve that for you.
How many telephone sockets do you have? What other devices do you have connected in addition to your router?
Does your master socket have a Test Socket
Are you experiencing any problems with your telephone service such as noise on the line?
j0nbinnie
Yes my router is connected to my master socket. It has a vdsl faceplate which my router is directly connected to. I only have a phone connected via an extension on the same line. What is my expected sync speed? Should I get an engineer visit?
Many thanks!
Jon
Hi Jon
Your predicted range is 19.1Mbps - 27.7Mbps
j0nbinnie
My router has been turned off a few times and the sync speed has now dropped to 13Mps and 6Mbps up. Details below.
Can you able to reset my profile so the DSLAM resets my sync speed?
Jon
xDSL
ModeVDSL2
Traffic TypePTM
StatusUp
Link Power StateL0
 DownstreamUpstream
SNR Margin (dB)11.96.0
Attenuation (dB)27.70.0
Output Power (dBm)9.77.2
Attainable Rate (Kbps)234416030
Rate (Kbps)130956013
B (# of bytes in Mux Data Frame)47188
S (# of data symbols over which the RS code word spans)0.11640.9988
L (# of bits transmitted in each data symbol)44001642
D (interleaver depth)5571
I (interleaver block size in bytes)64205
N (RS codeword size)64205
Delay (msec)160
OH Frames3238998214194695
OH Frame Errors25761
RS Words36722513824110945
RS Correctable Errors737455922599
RS Uncorrectable Errors17820
HEC Errors23990
OCD Errors00
LCD Errors00
Total Cells15646247270
Data Cells6558887500
Bit Errors00
Total ES36418
Total SES232
Total UAS892225073
Hi Jon,
Sorry, we can't reset DLM without arranging an engineer visit. Are you experiencing any problems with your telephone service such as noise on the line?
j0nbinnie
Yes I do have noise on my phone line. It has a crackling background noise. An engineer visit would be awesome. Thanks!
Jon
Hi j0nbinnie
Line tests are not picked up a fault, but ill log this to our network team.
If Our network team need access times and dates to arrange an engineer, can you read and understand the following Engineer charges help page you will need to agree to this to allow us to book this.
Then if you can send me via a Private message on the community with the best available dates and times for you, Monday to Friday, either AM (8am tilll 1pm) or PM (1pm till 6pm) for the visit we will book this.
