VPN AnyConnect connectivity issues
12 REPLIES 12
peterpeter
After getting a new Windows 10 laptop, I am unable to connect to VPN via Cisco AnyConnect. What steps can I take to fix this? My router version is FAST 5364-3.T8 and the firmware is SG4K10002600t.
Peter
There are no known VPN issues with the WiFi Hub at all. However, I have asked one of TalkTalk's OCEs to pick your thread up and investigate it for you.
Hi peterpeter,
I'm sorry to hear this. You're currently on the latest version of firmware for this router. What happens when you try to connect? Do you receive any  error messages? Does this affect wired and wireless?
peterpeter
Hi Michelle,
Thanks for your message. When I try to connect, I get an "unable to contact VPN" message in Cisco AnyConnect after it times out. It affects both wired and wireless. I'm able to connect successfully to the VPN when connecting using a non-Talktalk public wifi connection in a cafe.
Peter
Hi Peter,
Thanks for confirming this. As Keith advised, we're not aware of any specific issues with the wifi hub and VPN. Was the previous laptop able to connect to VPN via the wifi hub ok?
Have you tried factory resetting the router and then resetting this up again?
peterpeter
Thanks, Michelle. I was able to connect to the VPN with my old laptop. I just tried a factory reset of my router, but I still have the same issue.
Hi peterpeter
This router and firmware version should work with VPN.
I can send a replacement router for testing to rule out any possible issues with your current router. Would you like me to arrange this?
peterpeter
Thanks Debbie. Is it going to be exactly the same model of router? If you think it's a possible solution, I'd like to try it.
Hi peterpeter
Yes this would be the same make and model of router, will this be ok?
peterpeter
Hi Debbie,
That's fine - let's try a new router in case it helps. Is there anything else I can try before the new router arrives? It feels like the router isn't the issue, I was able to use the VPN on the old laptop successfully until right before I got the new laptop (I don't have the old laptop anymore, otherwise I would try it out).
Hi peterpeter
peterpeter
Many thanks Debbie!
