Very low speed Fibre large with fibre boost
RinRin
I've been your customer for more than 2 years now. I moved to Birmingham from London two months ago and since then my connection speed dropped drastically! My area is covered by your service so I don't understand why this happend. I pay to get 76mb and your collegue in the customer service was not very helpful with my issue.
I am really fed up with this situation as I can't even stream Netflix...
My PC is connected with ethernet cable and these are the results:
Internet Connection
DSL synchronization status: Up
Connection status: Showtime
WAN IP Address: 92.2.252.39
Primary DNS Server: 79.79.79.79
Secondary DNS Server: 79.79.79.80Line Quality
Upstream line rate (kbit/s): 12436
Downstream line rate (kbit/s): 27397
Upstream noise safety coefficient (dB): 6.2
Downstream noise safety coefficient (dB): 13.3
Upstream interleave depth: 157
Downstream interleave depth: 2309
Line standard: VDSL2
Upstream line attenuation (dB): 0.1
Downstream line attenuation (dB): 9.1
Upstream output power (dBm): 6.8
Downstream output power (dBm): 12.8
Channel type: Interleaved
DSL up-time: 0 days 0 hours 20 minutes 27 seconds
6972173799
Hope someone can help me...
RinRin
I did another speed test today and there is not much difference loud crying face
WAN IP Address: 92.2.253.72
Line Quality
Upstream line rate (kbit/s): 11657
Downstream noise safety coefficient (dB): 14.2
Upstream interleave depth: 149
Downstream line attenuation (dB): 9.4
Downstream output power (dBm): 12.3
DSL up-time: 0 days 4 hours 56 minutes 2 seconds
6973857792
RinRin
I opened a topic about this problem two days ago but no one answered me...
Internet Connection
WAN IP Address: 78.145.211.81
Line Quality
Upstream line rate (kbit/s): 11523
Downstream line rate (kbit/s): 24999
Upstream noise safety coefficient (dB): 6.3
Downstream noise safety coefficient (dB): 16
Upstream interleave depth: 145
Downstream interleave depth: 2107
DSL up-time: 0 days 9 hours 15 minutes 44 seconds
6977903210
I have merged your topics. It looks from your router stats that you may not benefit from the Fibre Speed Boost, this will only be of any use if your sync rate is significantly above the base rate of 38Mbps which yours isn't on the information you have posted, although the downstream SNR is quite high so there may be an issue there.
If you would like the online support team to look into this for you make sure that your personal details including TalkTalk landline number are complete on your community profile here so that they can link your forum identity with your account and then give them a day or two to respond.
RinRin
Thank you for your reply ferguson. I completed my online profile with all the details. Hope the online support team can find a solution soon.
Do you need any other information about the router to help me with my issue?
Not about the router itself no, but: is the router connected at the master socket; do you have any telephone extensions in your home; and are you aware of any noise on the voice service at all?
RinRin
The router is connected to master socket which is upstairs. There is one extention downstairs where the telephone is connected. There are filters in both sockets. The voice service works fine and clear.
Does the master socket have a test socket? If so try connecting the router there and see if it makes any difference to the connection speed. If not, unplug everyting from the extension socket and reboot the router, see if that helps.
Hi RinRin
Apologies for the delay.
I've completed a line test which hasn't detected any faults and your line is in sync at 25mb. There are re connections showing on the line which can affect the sync speed. Is the connection dropping or has the router been rebooted?
It would be worth leaving the router connected at the test socket for at least 48hrs without rebooting, to see if DLM makes any changes to the line profile.
RinRin
@ferguson Yes the master socket has a test socket and I tried few days ago to connect my router to it. The speed was low as always :(
@OCE_Debbie Sometimes my router reboots alone and I get disconnected. I'll keep the router connected to the test socket for 48hours then. This situation is really frustrating, if one device is connected to internet the other one struggle even to load a simple image.
I would persevere, internal wiring can absolutely kick out your broadband performance. The ideal situation is one master socket with nothing else connected to it, extensions are evil!
Hi RinRin,
Thanks for the update. I've re-checked the connection stats and I can still see a few re-connection so I've updated the router firmware.
Could you retest and let us know if there are any improvements in stability following this.
RinRin
@OCE_Michelle Thank you for updating my router but the speed seems the same loud crying face
Internet Connection
WAN IP Address: 78.145.210.147
Line Quality
Upstream line rate (kbit/s): 13790
Downstream line rate (kbit/s): 22399
Downstream noise safety coefficient (dB): 17.1
Upstream interleave depth: 176
Downstream interleave depth: 2723
Downstream line attenuation (dB): 8.9
Downstream output power (dBm): 13
DSL up-time: 0 days 0 hours 22 minutes 45 seconds
6988473051
Hi RinRin,
DLM will only increase the sync speed if the connection remains stable. Could you let us know if there is any improvement in stability over the next 24hrs following the FW update.
If the connection remains stable then DLM should start to increase the sync speed.
Is the router still connected at the test socket at the moment?
RinRin
Yes, the router is still connected to the test socket. I kept it like this for more than 48 hours.
Hi RinRin,
Ok thanks for confirming this and let us know how the stability compares over the next 24hrs.
RinRin
I didn't get any disconnections in the last 24 hours. The router is still connected to the test socket. Can you now try to improve my speed, please? Seems it's getting slow and slow...
Internet Connection
Line Quality
Downstream noise safety coefficient (dB): 18.4
Downstream output power (dBm): 13.2
DSL up-time: 1 day 1 hour 2 minutes 20 seconds
6991789138
Hi RinRin
I can still see re connections on the line. I can send a replacement router for testing, would you like me to arrange this?
RinRin
@OCE_Debbie Is it free of charges? If so could you arrange it please?
A new router is on the way for testing.
This should arrive in the next 24-48 working hours.
OCE's Hours of Operation - Mon to Fri 8am to 4pm. Urgent issues outside these times, please use Live Chat
Make Broadband Better - Join The Sam Knows Trial
