Very slow / no broadband.
3 REPLIES 3
krisad13
Hello, my broadband is extremely slow today.  It's been pretty bad for the last month and cutting out all together at times, max speed has been about 25 when it should be 60+.  I've put up with it as I'm moving soon.
Since last night the speed has never been above 12-13 and dropping frequently, it's very difficult trying to work like this.  Any of the tech guys able to assist?  Any known problems in my area? NE34
I've already reset through router for the 30 mins, this is happening with both wifi and ethernet.
krisad13
Also want to add that the router is now plugged directly into the main socket and still the same result. 13 download 3.5 upload
Skynet_TX
Hi @krisad13,
If the routers connection is dropping a lot then this will have a knock on effect on your speed, the equipment in the street cabinet will keep reducing your speed in an attempt to stabilise your connection. Once the fault is fixed and you have a stable connection again the speed should start to increase within a week or so.
It would be worth going to the Service Centre to do a test on your phone line, this will indicate if there is currently a fault on your line. You can also access this from the ‘My Account’ site.
If your master phone socket has a test socket then you could also try the router in there, that would then eliminate any of the phone wiring in your home as being a possible cause of the problem.
The staff on this community won't be around until Monday now, so you may get faster support by using the live chat or phoning up over the weekend, however the staff here should respond to this topic early next week to help if you are still having issues.
OCE_Debbie
Hi krisad13
I've completed a line test which hasn't detected any faults and your line is in sync at 73.9mb.
Have you tested with a different router?
