This is seriously annoying me got to beg for the internet not to go down when in competitive gaming / this seems to be all the time and happens anytime
Hi Kieran,
I'm sorry to hear this and I'll take a look now. I've run a test on the line which hasn't detected a fault, however I can see re-connections on the line.
Just to confirm, are you experiencing any issues with the voice service such as no dial tone or any noise on the line when the connection is unstable?
What make/model of router do you use?
No that's fine , when I had BT broadband there was barely a disconnection
Hi Kieran,
Thanks for confirming this. Does your master socket have a test socket? Do you have an alternative router that you can test with to see how the stability compare?
Um , I don't have a spare router at all ,I had a few issues with bt router before but we got there in the end , I did the socket test with bt a few months ago and they said it was all fine , they found a fault outside of the house which was fixed the only conclusion I can come to is this talktalk router hasn't been configured correctly which is leading to the disconnections.
Hi KieranKelly01
I can send a replacement router for testing, would you like me to arrange this?
Hi KieranKelly01
Hi KieranKelly01
Please can you test with the replacement router for at least 24hrs and let us know how you get on?
Hi Kieran,
Just checking in to see if the replacement router has arrived yet?
Yes it came yesterday , speeds seem faster on it and more stable , only time will tell.
Ok, no problem. Test for a day or two and any issues report back.
Hey it's been a few days , this router seems a lot better only 1 DC , due to update on the router, and speeds are a bit quicker
Hi Kieran
Thanks for keeping us updated, please let us know if you do experience any further issues.
