WIFI GOES DOWN EVERY SUNDAY AT SAME TIME
9 REPLIES 9
I have already made a post about this and got NO reply. My WiFi goes down every Sunday night between 12am - 2am. I have done all the appropriate tests and was on the phone to technical support for 2 HOURS. If something isn’t done I will be moving to Virgin
K. Grant
Is it only wifi that is off, does this affect any wired connections ?
Yes it’s affects everything. I’ve already checked this multiple times, as I said I was on the phone to technical support for over 2 hours when it was playing up. Ive done ALL the checks you’ve asked me to do and even spoke to technical support on live chat. I’m not the only one suffering from this so it’s a problem on your side. All people around the uk are getting the problem at exactly the same time I am. Fix this
K. Grant
Hi Kriziakay,
Could you confirm if HomeSafe is active?
TalkTalk HomeSafe - An Overview
Yep, it’s active. How many more questions before you fix this?
K. Grant
Hi Kriziakay,
Thanks for confirming this. Could you try switching HomeSafe off and once this has completed then switch HomeSafe back on again please. This should then hopefully resolve the issue the you're experiencing.
And if it doesn’t fix the issue???
K. Grant
Hi Kriziakay
Did you switch HomeSafe off and then back on again?
Yes, but what happens if this doesn’t fix the issue?????????
K. Grant
Hi Kriziakay
Then we will raise this to our Network Team. Please let us know if this still happens on Sunday.
