WIFI OPTIMISATION
ANSWERED
21 REPLIES 21
Could wifi optimisation be switched off please on my router as the channel keeps changing overnight and not to the best one.
Hi PLBBBERT,
Our performance monitoring tool will only change channels when interference is detected.  It will learn about each device that is connected over time.
However our Products Team have advised if you are experiencing issues and would prefer to select your own wireless channels then we can arrange for Wi-Fi optimisation technology to be switched off on your line. Would you still like us to remove this for you?
Solution
Hello Michelle,
   Thank you for your reply.   Yes would appreciate if you would remove wifi optimisation.   Did reply "yes" to an email I got but thought I'd do it here to.   I have been in touch with someone else at talk talk via email and they were adamant that they could not turn off wifi optimisation so may be a good idea to make them aware that it is possible.   Thanks for your help,
Hi PLBBBERT,
Could you PM me the last 3 digits of the router serial number (the serial number should start with N7)
Hello Chris,
   Replied to you email with details, but thought I'd do it again here.   Last three numbers 819,
Hi PLBBBERT,
Just before we switch this off our Products Team have asked us to confirm specifically why you would like this switched off? Is it affecting the performance of your connection?
Hello Michelle,
   The reason I want wifi optimisation switched off is because, with it on, the channels change. for no apparent reason and not to the least congested or channel with the best signal.   It does this most nights and sometimes during the day.   The router has settings for automatic or to select the channel you would like , but this does not work.   In the past I was sent an exchange router to stop this happening but it still happens
Hi PLBBBERT
This has now been switched off, please let us know how the connection compares following this.
Router was on channel 1 last night, this morning is on channel 11, so not worked yet.
Last night router changed channel from 1 to 11?
Hi PLBBBERT
Apologies, please can you test this again today and let me know how you get on?
Hello Debbie,
   Thank's for your efforts.   Now seems stable and channels are staying as I select them.
Hi PLBBBERT
That's great, thanks for letting us know 🙂
Hello Debbie,
   Just to let you know channel changed from 6 to 11 during the day yesterday.   Checked router and this showed the setting was on automatic so changed to channel 6.   Hopefully this was a one of blip, but will let you know if it changes again,
Hi PLBBBERT
How has the connection been since your last post?
Hello Debbie,
   So far has stayed on channel 6 and shows on channel 6 in router, not "automatic", so seems may be OK,
Hi PLBBBERT
Thanks for your reply. Please let us know if you do experience any further issues.
Debbie 🙂
Hi Debbie
   Channel changed from 6 to 11 then to 6.   Is showing on router as auto, changed to 6, lets see what happens.   Why is it changing itself to auto?
                                Paul
Hi PLBBBERT
Apologies, I'm not sure why this is happening as it still shows as switched off.
Is this affecting the performance of the connection?
Hello Debbie,
   Thanks for your reply.   Router is staying on channel 6, the one I put it on, and seems stable at the moment.   I'm not getting connection problems but like to be on the least congested channel.   I don't know if the talktalk TV box could have anything to do with the problem, but suspect you would know if if it had, anyway, uses port 1024 (I think).   Will again stick with it, it doesn't happen as much as it did,
