WPS to connect wireless printer
3 REPLIES 3
I’ve been trying to use WPS to connect our Canon wireless printer to our new wi-fi hub.  I’ve followed instructions with the printer and the wi-if hub but the LED on the hub remains white, it doesn’t flash orange.  Any ideas please.
Problem Solver
To be honest I would forget using WPS.
Presumably your printer has a wifi connection wizard. Use that and manually select the hub's SSID from the list shown on the printer. Enter the password and you should be good to go. The wifi SSID & password should be on a card on the back of the hub.
Fritz
Hi couldn't agree more with what @FritzCT has said. WPS is even more frustrating than my wife.
Thanks Fritz, I’ll try that instead.
dilys
