What does wym105 code mean
Trying to access my broadband TV but get tha code WYM105 All other devices are connected fine just having problems with TV any ideas
Kay
Insightful One
What is giving you the error code? If it is the TV it might be worth checking the manufacturers form/help pages. It would also help if you provided the make/model here, so if someone reading your post has the same/similar model they might be able to offer advice on setting it up.
Do you mean yvm105 on the box?
if so try this.
https://support.youview.com/youview-box/error-messages/fix-for-yvm105/
