Search instead for
Get Searching
Search now
Get stuck in
Try now
Join the party!
Register now
What is cause of error 0x800421A
whitelawfam
I'm sending emails through Outlook but the receiving is giving error message 0x800421A.
If restarted PC and restrated router but still getting the error
 quick Google search for it came up with this article on how to resolve this problem:-
http://www.wikihow.com/Fix-Outlook-2003-0X800421a-Error
Hi whitelawfam,
How are you getting on? We have been experiencing some issues with our email platform over the weekend which may be causing your problem. (you can find the latest update on the email issue here)
