What speed should I see?
Foxyladyaccountant
Hi @KeithFrench  I hope you had a restful weekend? Sorry for the delay in reply.  I needed to catch up on work, etc.
I have set 5GHz to channel 52 and 2.4GHz to channel 6.  Ive taken some screenshots from the first floor bedroom, which is virtually above the location of the router.  I think the One Drive transfer rate has improved slightly.  I will upload some screenshots now.
I believe the BT wifi extender (repeater) does have a log in console, so I will find the log in details and come back to you.
Be kind. Be silly.
Foxyladyaccountant
2.4GHz Networks2.4GHz Networks
Be kind. Be silly.
Foxyladyaccountant
2.4GHz Network Quality2.4GHz Network Quality
Be kind. Be silly.
Foxyladyaccountant
2.4GHz Signal Strength2.4GHz Signal Strength
Be kind. Be silly.
Foxyladyaccountant
5GHz Networks5GHz Networks
Be kind. Be silly.
Foxyladyaccountant
5GHz Network Quality5GHz Network Quality
Be kind. Be silly.
Foxyladyaccountant
5GHz Signal Strength5GHz Signal Strength
Be kind. Be silly.
Hi @Foxyladyaccountant
That looks good on the first floor. I can't see your extender listed, so I assume that is turned off. If it still is, please can you get me screenshots from the loft, whilst it is turned off? However, if the extender is still on, then let's wait until you have seen what configuration changes it offers.
Foxyladyaccountant
Hi @KeithFrench
The extender is still unplugged, here are the 5GHZ photos.  Surprisingly, the transfer rate of the One Drive download isn't affected much.  It definitely seems consistently better, since changing channels.
Loft 5GHz Signal StrengthLoft 5GHz Signal Strength
Be kind. Be silly.
Foxyladyaccountant
Loft 5GHz Network QualityLoft 5GHz Network Quality
Be kind. Be silly.
Foxyladyaccountant
Loft 5GHz NetworksLoft 5GHz Networks
Be kind. Be silly.
The 5GHz ones don't look too bad, what are your speed tests in the loft like now?
