What upload speed should I be getting?
Hi Shanemorris
The previous engineer has left notes to advise the following:
There was a fault with the end customer's equipment / mis-operation. The fault was resolved by an advice given to the customer. Engineer has visited end customer premises. Customer's modem / router is not plugged into the NTE master socket.
Have you made any changes internally since the engineer visit? Do you still have the HG633 router we previously sent?
Same router same place no changes made.
Hi Shanemorris
Did the engineer say anything about the router location or move the router?
Do you still have the HG633 router?
No same location for router, yes still have it.
Hi Shanemorris
Would it be possible to swap the router to the HG633 for 48hrs? If you are still experiencing this fault following this then we will need to arrange another engineer visit.
plugged in the 633 at 6pm  and instantly got 28mb download so it looks like router is faulty? I’ve monitored it all evening and hovered around the 28-30 mark.
Thanks for the update. Would it be possible to monitor the connection and speed for a few days with this router connected to see how it compares?
