Wi-fi Hub v super router.
ANSWERED
5 REPLIES 5
joemardo1
Wizz Kid
Hi folks,
I see that the wi-fi hub is being well advertised by Talktalk. I do have a super router but always looking for ways to improve my wireless connection.
Is the so called Hub that much better than the super router and wonder if it has any extra additional features.?
Many Thanks.
Joe
Joe
Solution
The hub has a much higher Wi-Fi specification (802.11ac wave 2). However, unless you have similar specification Wi-Fi adapters, you will not be able to take advantage of this.
Wi-Fi is a very variable medium & it is impossible to guarantee improved results. Therefore, before replacing your current router, you should really check out the state of your wi-fi network in terms of interference. I can help a lot with this if you require it.
joemardo1
Wizz Kid
Thanks a lot Keith, its not that the wireless is particularly bad, I was just wondering if it would have been easy for the Hub to make a difference.
Probably will just wait as a loyal customer of Talktalk, until they offer me one.
Thanks again.
Joe
Hi joemardo1
If you contact our Customer Service Team then they can discuss sending a Wifi Hub.
joemardo1
Wizz Kid
Thanks Debbie all sorted.
Joe
