WiFi Extender Kit
5 REPLIES 5
The article by Tayler on pairing WiFi Extender Kit with TT Powerline Adapters talks about wireless Powerline Receivers . Does anyone know how to connect the Extender Kit with the old non wireless Powerline Receivers ?
Mitch
Hi @mitch88 pretty sure you just have both plugged in then press the pair button on the node you wish to add then on the node attached /nearest to router.
Good luck, please advise results
D
Thanks Divsec , I will let you know how I get on .
Mitch
Hi Mitch
How are you getting on?
Apoliges to everybody for not getting back sooner , I was away for four weeks then when I came back I was a bit aprehensive in tackling this . However I bit the bullet today and it worked first time . In the area I wanted it for , my speed lept from 4gb to 67 gb . Result !  Thank you for all your replies .  Mitch
Hi @mitch88 now that is a result. Thanks for the update.
