WiFi Extender Kit
3 REPLIES 3
I'm looking at getting a WiFi extender kit as Wifi is patchy in one part of the flat, but I already have a Network Connector which I use with the TV box.  Does anyone know if it's possible to have both running from the same router?
Thanks!
Yes, that should be fine. I have just tested two WiFi extender kits where each extender is connected to its own network connector, therefore using two ethernet cables to two LAN ports on a Sagemcom WiFi hub and they both maintained the powerline connection between them.
Thank you!  I'll order one and see how it goes 😀
Hi squemma,
I can see Keith has answered your question, just let us know if you need any further assistance
