WiFi Hub configuration file not saving properly when backing up
I have just received a new WiFi Hub with firmware SG4K10002600t, and set up friendly names and port forwarding. Having saved a backup config file and then doing a restore to test it, it has not retained the information!
Having re-entered all the info again I am reluctant to again lose it by doing another restore.
But can I trust that there is not a bug in the firmware?
This is not a backup & restore bug. Losing the friendly names is a bug I highlighted when I first tested the router. There is new firmware being developed (no release date as yet) which is hoped to fix quite a number of bugs that I have reported. However, currently, I have no idea as to exactly which ones will be fixed.
Hi AndyyRoo
We should have an update on the fixes in the next firmware version soon and also the release date.
