Hardware Version FAST5364 3.00 S/W Version SG4K10002600t GUI Version 3.7.5
I can no longer disable my static DNS setting, this worked before as I was using TT DNS then switched to googles, now its showing as googles and I cannot change them, when did this version or software get installed on my router? Also there is no longer any tools under maintenance such as ping or traceroute, I suspect a change was made around 6th Aug, as I have a SamKnows white box and since that date it has not been able to run Dns over HTTPS (DOH)
Hi kpf61
This is the current firmware version for the Wifi Hub. We have new firmware in testing and once this has been fully tested then it will be rolled out to all Wifi Hubs.
@OCE_Debbie Hi Debbie, interested in your comment, are you saying all existing Fast5364 boxes should now be running SG4K10002600t ?
