WiFi Hub light changing from white to orange
9 REPLIES 9
SamLeyland
I have had the WiFi Hub for a couple of years with very few problems, just recently say in the last three months the Hub has been switching off the White light and changing it to the Orange light, I have got to reboot Hub to get it back online.
I have spent about 40 mins going round in circles with TT Chat who do not seem to get the point that irrespective of their tests everything looks okay, tried telling them that this is an intermittent fault and can be okay for a while then the Hub will go from White to Orange and then require reboot.
Can you please help as this is very frustrating
Thank you
OCE_Karl
Hi Sam
All the usual line tests are clear, no issues stand out.
I can see an increase in authentication logs, so can see drops in the connection.
I've a router on the way to you so we can rule out a hardware issue.
SamLeyland
Hi Karl
Thank you for quick response I will look forward to the replacement WiFi Hub.
Is there any package that can give me better Download Speeds (talktalk speedtest shows 40mbps but Ookla own test shows about 19 - 23 mbps)
Sam Leyland
OCE_Karl
Hi Sam
The speed range for your line tops about 55mb.  You could try adding the speed boost via My Account if the option is available, but realistically you may only see an increase of about 10mb.
SamLeyland
Hi Karl
Thank you once again for your quick response
Sam Leyland
OCE_Chris
Hi Sam,
If you need further assistance please let us know 🙂
SamLeyland
Hi Chris
Thank you I will if I have further issues after trying replacement WiFi Hub
Sam
OCE_Chris
SamLeyland
Hi Chris/Karl
I have connected the new WiFi Hub today, the first thing I noticed was that the White Light appears to be a lot brighter on the replacement WiFi hub than on the old WiFi hub?
I will monitor the Hub over the next few days/weeks.
Thank you both for your help.
Sam Leyland
OCE_Karl
No Problem 🙂
