WiFi Hub
leozak000
Is the wifi hub the same as the router ?? I see there is a upgraded wifi hub does that replace my existing router ??  John
FritzCT
Wise Owl
Yes the hub is the router. I believe the upgraded one looks identical to the 5364 but is black & made by Huawei.
Fritz
OCE_Debbie
Hi John
We have 2 WIFI Hubs, they are just different make and models. One is Sagemcom and the other is Huawei.
Are you experiencing any issues with your router?
