WiFi disconnects randomly.
6 REPLIES 6
jesusjones
WiFi connections disconnect across all devices randomly, sometimes up to 5 times an hour.
Router is a HG633, have tried a factory reset and the issue still occurs. Any suggestions?
Cheers.
Divsec
Hi @jesusjones welcome to the community your post has been flagged for assistance and you should hear during tomorrow. Please check your community profile and add your landline phone number if necessary it is used to identify your account please don't post personal details here:-).
You have tried the obvious self help actions so will likely need help from the OCE team.
How long have you had your router?
Has any new electronic equipment arrived in the house recently?
jesusjones
We've had the router since having fibre installed so over 2 years now I guess. No new electronics.
Divsec
Thanks for that it will help the team a lot.
I'll get a replacement out to you and see if this helps.
jesusjones
Ok I shall update you when I receive it.
Many thanks.
