WiFi dropping at various times of the day
21 REPLIES 21
For a few weeks my WiFi connection has been dropping to all of my devices. Sometimes it comes back on itself or I need to switch the router off and on. There are times where this doesn’t help at all and I can be without WiFi for hours. I have tried the online chat on a few occasions but they are unable to solve the issue, testing the line and getting me to mess about with the master socket. I know there is no problem with the line to the house as I have a PC connected by Ethernet which is unaffected and I can still watch Netflix etc through the tv box which is also hard wired by Ethernet. I have followed the guide to try and resolve the dropping WiFi. I thought I had fixed it by manually selecting a WiFi channel but after a day the dropping started again. I have suggested on the online chat that maybe a new router could be sent. I was told last week that this was an option but to monitor the situation for a couple of days first. There was no improvement but when I contacted talk talk again they wanted to send an engineer. Can a new router be sent out in order to try and resolve this? As far as I am concerned there appears to be a router problem.
To enable me to help you, please can you specify the make/model of TalkTalk router that you are using?
HG635
The HG635 is a dual-band router & offers both the older 2.4GHz & the newer 5GHz Wi-Fi bands. The problem is these are two different networks (SSIDs), but they share the same name, so you can't tell which one you are connected to. Log into the router (http://192.168.1.1) and enter a username of "admin" and uses a default password of "admin", like so may older routers.
Go to:-
"Customise my wireless network"
Append "5G" to the end of the network name of the "Wireless 5 GHz SSID" field. Then click "Save".
This will not fix your issues, but it will make it much easier to identify the band you are connected to. This way you will know which band is causing your problems.
You may then wonder what was really the point of this if it won't solve the problem? This is because the whole topic is too complex to be dealt with in one post. The next stage involves sending out a guide to you to help you get me some important diagnostic results, so as I can analyse them for you and recommend changes to your router configuration to solve them.
I am not at home right now but can you send me the guide.
I will PM you a link for a guide of mine on Wi-Fi interference & initially look at the section called "Are you suffering from interference – prove it first". This section includes full details of Wi-Fi analysers that I recommend for Windows, Windows phone, Android and Apple operating systems. However, I have no way of testing the Apple product. Do not worry about interpreting the results, I will do that for you.
Please post the screenshots that I have requested in my guide (no photos please they can be difficult to read as text can get out of focus when zoomed), from the analyser you are using (also in my attached guide). Please ensure that the analyser window is maximised (if Windows) before taking the screenshots & upload them via the "Insert Photos" button (in a mobile browser it's the picture icon) on the post editor's toolbar as large images. If they are too small, I will not be able to read them & although I can enlarge them, this just puts the text out of focus. If you prefer PM them to me. If you do PM me, then please add a link in there to this thread, so as I can find it easily.
Ok will get it sorted later today
I am not able to send you a PM, as your PM's are not enabled. I am waiting on TalkTalk to enable your PMs.
Ok
Community Manager - TT Staff
done Keith
Stephen, Community Manager
Our latest Blog l Share your Ideas l Service Status l Help with your Service l Community Stars l Set your preferences
Hi @StephenF thanks for doing that.
Hi @well1991  I will PM you now.
You problem affects both the 2.4 & 5GHz bands & is not caused by WiFi interference. If you look at any of the signal strength graphs that you have sent me, they should each be one continuous fairly straight line. Yours are nothing like that, they are breaking up all over the place. I would tend to think this is either electrical interference, location or possibly if a USB WiFi adapter, power management is affecting it.
This is the best router location, but obviously, this is not always practical & a compromise has to be reached.
The general rule is to keep it away from:-
  1. Cordless phone (DECT) base stations
  2. TVs
  3. Loudspeakers & any sub-woofers (including those used with a PC)
  4. Computer monitors
  5. Electrical appliances – they often transmit their own signals that can interfere with Wi-Fi signals.
  6. Bluetooth devices – they operate on the same Wi-Fi frequency as your broadband, which can cause signal problems.
  7. Mirrors – they actually reflect Wi-Fi signals, stopping them from passing through walls and reflecting them back into the room.
  8. Anything containing large amounts of water – things like fish tanks and boilers can absorb Wi-Fi signals like a sponge.
  9. Large metal objects – radiators, for instance, will have the same effect on your Wi-Fi as mirrors. If you have a tower PC case with an internal WiFi card, the metal of the case can block signals to & from the antennae if they are located behind the tower case.
  10. If you are using a USB Wi-Fi adapter, use a USB socket on the front of the PC, as there is more open space around it than at the rear. If a USB extension cable is used, try to ensure that it is fairly short, so as the power from the computer is not attenuated. Long extension cables can cause the adapter to not have enough power from the computer to work correctly.
As a very general rule, the signal travels best on the same floor as the router and to the floor below. It does not always propagate very well to a floor above the router. However, with more modern routers, if they have a higher specification, they may be able to get the signal upstairs OK, but your ability to receive it also depends on your device's network adapter being of a higher specification, as well as its age.
Where USB is concerned, power management is best disabled if running in Windows to keep a Wi-Fi connection working at full speed. Once having made the changes outlined below, it is probably best to restart the PC.
To do this in Windows 10, right-click on the network icon in the Notification area & select Open Network & Internet settings. Then click on Change Adapter options. Next right click on the Wi-Fi adapter & select Properties. Click the Configure button.
Click on the Power Management tab & untick Allow the computer to turn off this device to save power.
Why has it only recently started happening when nothing has been changed regarding the set up or location of the router or any change to the surroundings? Everything has been fine up until a month or so ago with no issues since I have been with talktalk. I am having to restart my router on numerous occasions when previously I didn't have to touch it at all. To me the explanation doesn't make sense. Is there not any possibility of another router being sent for me to test?
Hi well1991,
I'm sorry for the delay. How you getting on?
Still getting drop in WiFi. I don't understand the explanation from Keith above. There have been no changes to my set up or any additional devices. I have been with talktalk for a few years with no problem and been very happy with the service. But since I took out a new contract earlier this year I've had constant drops in the WiFi signal. I would appreciate if a new router could be sent to at least test to see if this is a possible solution. My wife is currently working from home and needs reliable WiFi for video calls. If this can't get rectified I may need to look for another ISP.
Hi well1991,
I've ordered a replacement router, it should be with you within a couple of days but please allow up to 5 working days for delivery
Ok thanks
An update on the wifi issues.
I received the new router on Wed 9th Sep and got it set up straight away with no issues.
There has been no problem with the wifi until tonight, Fri 18th Sep.
We had wifi dropping on a number of devices including mobiles, tablet and xbox one.
The router was switched on and off which has currently resolved the above.
Hopefully this is a one off but will get back in contact if it persists.
Hi well1991
Apologies for the delay.
How has the connection been since your last post?
