Using a TalkTalk Huawei hg 655 router, been through on line chat with TalkTalk doing the usual checks but not identifying any faults still WiFi continues to drop out. Have asked if a replacement router could be sent out to no avail, please could one be sent to rule out this old router.
The HG635 is a dual-band router & offers both the older 2.4GHz & the newer 5GHz Wi-Fi bands. The problem is these are two different networks (SSIDs), but they share the same name, so you can't tell which one you are connected to. Log into the router (http://192.168.1.1) and enter a username of "admin" and use the current router password.
Go to:-
"Customise my wireless network"
Append "5G" to the end of the network name of the "Wireless 5 GHz SSID" field. Then click "Save".
This will not fix your issues, but it will make it much easier to identify the band you are connected to. This way you will know which band is causing your problems.
You may then wonder what was really the point of this if it won't solve the problem? This is because the whole topic is too complex to be dealt with in one post. The next stage involves sending out a guide to you to help you get me some important diagnostic results, so as I can analyse them for you and recommend changes to your router configuration to solve them.
Thanks Keith. Have already split the two ssid's & no new devices have been added to my network. All wired connections drop connection too, this leads me to think it’s a router problem. The problem started around a month ago and has persisted which is why I believe it to be related to my old router. Ruling this out with another router would help to pin point. Had a similar experience with a netgear router some years ago.
In that case, it may well be a router or a line problem. I have asked one of TalkTalk's OCEs to pick your thread up and investigate it for you.
Hi Keith,
Have not been contacted by TalkTalk yet & router has now intermittently stopped transmitting 2.4ghz ssid, any idea when they may be in touch?
@smithi67, there tends to be a backlog after the weekend and, although it's been escalated, further posting will push your thread back again in the workflow.
It's best not to post further till you get a response from an OCE. They will reply on here in the forum.
Hi smithi67
Apologies for the delay.
I've ordered you a replacement router, please allow 24-48hrs for this to arrive.
New router set up & no problems at the moment, thanks for your help.
Hi smithi67
That's great news 🙂 Please let us know if you do experience any further issues.
