WiFi issues HG635 Super Router
6 REPLIES 6
farsu436
On version v1.14t, but quite regularly now WiFi stops working (No internet) while still being connected. After a while connection returns. Have reset router and but still same issues.
Another SSID on 5 GHz Frequency Band works fine (so far). However, not all devices in our household support that frequency.
Would be nice to hear from anyone from TT.
Hi farsu436
Apologies for this.
Have you reset the router using the pin hole reset for ten seconds?
farsu436
Hi Debbie
Yes, I did but it didn't help.
Hi farsu436
I can send a replacement router for testing, would you like me to arrange this?
farsu436
Yes please. Thank you.
Hi farsu436
farsu436
HI Debbie
The HG633 router that you sent had exactly the same intermittent issues on 2.4 GHz frequencies. Moreover, it is much slower than HG635 when it works. I've now returned to my old router (HG635) and managed to stabilize it at channel 11. No problems for the last several months. What do you want me to do with the one that you sent i.e. HG633? I've got a return bag from you which I can use to send it back to you.
