WiFi will only connect to certain apps, all safeguards have been turned off to overcome this with no luck. Had the WiFi 7 months and issue has just started. Apps/phone/tv aren't the problem as will work using only mobile data.
Any help will be appreciated?
Cheers Guys,
Aled
Hi Aled
We'll then look into this further. Please do not post this information on this thread. Once you've updated your profile please post in your topic to confirm it's updated.
