WiFi password
4 REPLIES 4
I have lost the tag with the wifi password on. We changed it to a different password when Talk Talk had a data breach a few years ago so it isn't factory settings.
I would like to connect more devices to the WiFi so need to know it. Any advice as to what I can do ?
Wise Owl
Try WPS set up (you should really keep this off though)
Or connect via LAN and log into the UI where you should find the wi-fi password.
Fritz
Hi yowyeung,
I can see that Fritz has pointed you in the right direction, please let us know if you need any further assistance
thanks for the quick reply Fritz, much appreciated
All sorted I think, thanks
