Wifi hub lost connection now slow speed
17 REPLIES 17
Chat Champion
I’ve had good fibre speed of around 24 since getting the new wifi hub. I noticed the amber flashing light today and had to reboot to gain connection again. Now speed is stuck at 4 mbps. What could of caused this? Are openreach doing work?
First off, did you just reboot it, or power it off for a minimum of 30 mins? The latter is what you need to do, so as everything is cleared down from your previous connection. If still bad, let me know & I will ask an OCE to look into this for you.
Chat Champion
Thanks Keith, I have tried what you recommended today. It took over an hour when it came back on to reconnect and unfortunately the download speed is stuck at 4. I spotted an open reach engineer in our street so spoke to him. He mentioned two houses have no broadband and said to report it which I did. I had a text from TalkTalk saying they’d resolved it but clearly there’s still a problem. I’m guessing it’s been caused by an engineer as I’ve had no problems since having the new hub. What now?
Hi ktp500,
I'm sorry to hear this. I've run a test on the line which has detected a potential voice fault. Just to confirm, are you experiencing any issues with the voice service such as noise on the line or no dial tone?
Does your master socket also have a test socket?
Chat Champion
SpI haven’t noticed anything on the line. The engineer who was in street on Saturday was fixing a line. I feel they have done something for it to suddenly drop out and seed seems capped around 5? I do have a test socket. Can you see the speeds I’ve had since Friday
Chat Champion
I have just checked as tried to make a call and yes you are right I have no dialling tone. How does this affect broadband and what can you do to help?
Hi ktp500,
Your sync speed is 5.3Mbps, There is a fault ticket raised so I've asked our network team for an update. If you don't hear anything later today can you bump the thread again tomorrow
Chat Champion
Thanks Chris
yes speed is usually around 25. Do you have any idea what caused this? The openreach engineer I spoke to said other houses had same issues
Hi ktp500
I've requested an update from our Network Team and I will post back on this thread as soon as I receive further information.
Chat Champion
Bumping thread. Any news? We have lost connection completely again. I’ve had repeated problems over the last couple of years and hoped the new hub meant the end of these issues
Hi ktp500
This fault has been passed to a BT Openreach line engineer and we should receive further updates within the next 48hrs.
Chat Champion
So I don’t need to do anything else? Is it something Openreach can sort outside of my property? Will you inform me of any updates please?
Hi ktp500
The engineer will investigate the line outside the property first. If a visit to the property is required then we will arrange this visit with you.
I will check for further updates in 48hrs and post back on this thread to keep you updated.
Hi ktp500
I have requested an update on this fault and I will post back on this thread as soon as I receive further information.
Hi ktp500
BT Openreach have advised that this fault should be resolved. Please can you retest and let us know if this fault has been resolved?
Chat Champion
Yes it seems as though the line has been fixed. Thanks for your help
Hi ktp500
