Wifi issues - 5GHz not work, impacts 2.4GHZ
10 REPLIES 10
This afternoon my son started to complain that his phone kept losing connection to our home wifi. Checking on my wife's and my own phone I could see that neither were indeed connecting, despite the Wifi hub admin section telling us otherwise. In an attempt to troubleshoot the issue, I split the SSID on my hub to 2 different SSIDs. Our phones, 2 Google Pixel 2 and a huawei P20 , were able to see both SSIDs but were getting intermittent connection to the 2.4 GHZ band. Nothing was able to connect specifically to the 5GHZ band at all, keeps timing out. So I disabled the 5Ghz band and connectivity to the 2.4 Ghz band was restored, no issues.
This doesn't sound normal. I have tried setting the 5GHZ band to channel 44, but again none of our 5Ghz capable devices have been able to connect.
Is this a hub issue?
here are some of the versions from my hub
FAST5364 3.00
SG4K10001E00t
3.7.2
21d 21h21m35s
Disabling the 5GHz band should obviously not have any impact on the 2.4GHz band. Have you tried a factory default of the configuration?
the router was reset a couple of weeks ago and since then no changes to config have been made by me, so why would it suddenly stop?
Hi Cragdoo,
I'd like first of all to update your router firmware, is it OK to do this now?
Hi Chris
Yes , please go ahead and carry out the update
OK, I'm pushing out the firmware update to your now, should complete within a few minutes. Once it's complete please retest and let us know how you get on
HI Chris
I can confirm the firmware upgrade has resolved the issue. Thanks for dealing with this..
Craig
Hi Craig, that's great news, thanks for letting me know 🙂
I have the same problem log into router and says 5ghz down and when i try to connect to wifi it asks for WPA2 password HELP!
Hi Trapzprod1,
I'm sorry to hear this. Please can you create your own thread and we can look into this further for you.
