Wired Connection stopped working but wireless still works
I use a Huawei HG633 router . This is connected wirlessly and also wired connection to 5 d-link plugs. The wired connction has stopped working the 3 lights on all the D-link plugs are green.
The message on my computer in the network settings shows "Ethernet - Not Connected "and "uniditified network No-internet ".
Can someone please and advise how I can get the wird connections working again or is there something wrong with my router. Thank you
Hi UME40,
I'm sorry for the delay. Have you tried factory resetting the router and resetting it up again?
Restore your router to factory settings
Hi UME40
It sounds like you might have changed your network from private to public.
Windows 10 if you go in to:
Settings >Network and Internet. Status should say private if it says public go to.
Change connection properties just below and change it to Private. Mark
