Wireless package erors
ANSWERED
3 REPLIES 3
grouser
Can some knowledgeable person cast an eye over this for me please and advise if it's normal or have I a problem,if so how can I rectify it.I seem to have a largish amount of package errors,I'm not that Tec minded but need to know if it's normal or not ..Thanks
Solution
That snapshot doesn't really tell us much one way or the other and in any event some router stats can be spurious. More important, are you actually experiencing any problems with your wireless connection?
If not, I really wouldn't worry about router stats. If you do have any problems let us know and we can try to address those.
grouser
Thanks for your quick reply,I'm not having any problems with wifi,I have just signed up to Faster Fibre and was just casting an eye over settings and things and seeing errors( Seeing words like that always makes me panic)..😂
Cool.  😎
