Yet again frequent WAN disconnects
Hi Debbie
I just wanted to update the post (I have also sent a pm) the engineer checked all internal cabling and was received errors on the tester and confirmed the issue was external cabling and would need some additional work (We later saw him lifting the manholes on the street) I then had to leave so didn't receive an update from the engineer the internet has been disconnecting still tonight.
Does this mean further works are needed?
Hi Lee
The fault is now showing as closed. Has the fault been resolved?
Hi Debbie
So far the sync seems to be stable as of right not it's been connected for (11h18m52s) so I will continue to monitor.
I wasn't sure whether you were able to see what they did to resolve?
Hi Lee
The notes only advise that work was completed outside the property.
Please can you continue to monitor the connection over the weekend and let us know if you do experience any further issues.
Hi Debbie
So far its definitely better WAN disconnects are much less frequent but they are unfortunately still occuring, That being said we have had very severe weather this weekend so I will continue to monitor
Hi Lee
Apologies for the delay.
How has the connection been since your last post? Is the connection still dropping and does it appear to be weather related?
Hi Debbie
Not a problem, We are still seeing drops, unfortunately (but certainly less frequently) looking at the logs it lost connection again at around 5am this morning but has been connected since we have had a large amount of rainfall over the weekend and the engineer from OpenReach said this can have an effect if some of the cables are submerged that being said its dry today so appears to still be an issue
Lee
Hi Lee
Apologies for this.
I've completed a further line test which hasn't detected any faults and I can see 1 re connection on the line today.
How many drops in connection have you had?
Hi Debbie
Yes today it was just the one overnight looking at the log files, Its tended to be overnight/early hours of the morning (When little to no usage is occurring) which is different as before it tended to disconnect during high usage (Large file downloads, HD streaming)
Thanks for your assistance
Lee
Hi Lee
I will check the connection stats again tomorrow to see how many drops we can see and I'll post back on this thread tomorrow with further updates.
Good morning Lee
I've checked the connection stats again this morning and I can only see 1 re connection yesterday.
How has the connection been for you since your last post?
Hi Debbie
Thanks for keeping me updated, Sorry for the delay I've just got home and checked the connection and it appears to be holding strong! So far current uptime is - 1d 15h14m14s which is a very good sign.
I will check again in the morning but by far the longest stable connection I have had for 2-3 weeks
Again thanks for your help
Lee
Hi ParkerP,
Thanks for the update 🙂
Good Morning Debbie and Michelle
The connection is still stable and hasn't disconnect, Uptime is now 2d 03h13m32s so I think it's safe to say its resolved.
Thanks so much for your assistance
Kind Regards
Lee
Hi Lee
That's great news, thanks for keeping us updated 🙂
Hi Debbie
I am afraid to say the issues appears to be returning, Currently the connection appears to reach a maximum of around 2 days and then disconnect.
Is it possible to run another line test please?
Lee
Hi Lee,
Line test is passing but I can see that there have been reconnections. How long is the connection usually down for? Does the router automatically reconnect?
Afternoon Chris
Yes router auto reconnects, Typically down for around 1-2 minutes (equivalent to manually rebooting router in reconnection time)
Kind Regards
Lee
Does there appear to be any sort of pattern to the disconnections, do they seem to happen when you're doing anything in particular?
is the router situated closed to other electrical devices that could be causing interference?
