broadback connection drops when phone rings
5 REPLIES 5
Buachaille
My router keeps disconnecting from the internet when the phone rings.
I've tried multiple microfilters and it's connected to the master socket.
The line test tool shows there is a problem. What are the best next step steps to take?
Hi Buachaille
I've completed 2 different line tests and both tests haven't detected any faults on the line.
Could you connect the router at the test socket? Do you have a different phone that you could test with?
Buachaille
I've plugged into the test socket. I don't have another handset to test with I'm afraid.
Hi Buachaille
Does the connection still drop when the phone rings? (with router at the test socket)
Buachaille
connection is ok in the test socket, does that mean my main socket is faulty?
Hi Buachaille
This would indicate a possible fault with the faceplate or internal wiring.
