cloudcheck
1 REPLY 1
anoyed
Whizz Kid
is there any way you can turn it off on my line keeps changing my channels to same as next doors bt hub Which almost wipes out my wifi till i change the channel which lasts for a while then it changes again the new firmware for the sagecom is rubbish takes most of your options away from you
dave
OCE_Karl
i'll get this turned off for you
