crackly phone line effecting broadband badly
16 REPLIES 16
Chat Champion
Noise on the line i need an engineer please im in the test socket using a microfilter.
broadband speed has been cut in half and is unusable at the moment.
7.6 dB / 14.2 dB
6.5 dB / 27.3 dB
5.1 dbm / 5.1 dbm
555 kbps / 8799 kbps
0 / 0
0 / 0
141 / 141
0 / 3847
Hi @stokeash
I will ask one of TalkTalk's OCEs to pick your thread up and investigate it for you.
Hi stokeash
The usual line tests are clear.
can you confirm the line is noise when tested with an alternative handset at the test socket ?
Once confirmed we can then begin the process for an engineer.
Chat Champion
Hi, Karl the tests are pretty much useless they never find anything haha, Having said that I think the noise is coming in bursts/ periods its causing loads of disconnections I cant stay connected for longer than 24hr and latency and speed is massively effected . I'll have another test later.
Ok, let us know when checked and we'll take it forward.
Chat Champion
Hi, I'm having a massive amount of disconnects now but the noise seems to have gone? I literally had about 20 disconnects yesterday the router is all over the place, could you run tests again because surely it'll pick this up? Thanks Karl.
Hi stokeash,
I'm sorry to hear this. I've run a test on the line which hasn't detected a fault, however I can see quite a few re-connections on the line. Is the router still connected to the test socket at the moment? Have you recently tested with an alternative router, microfilter and adsl cable?
Chat Champion
Hi could you please test again as the test on here is now picking up the disconnects and the speed has dropped from 18mb to 11mb theres something wrong for sure. This is in the test socket.
Hi stokeash
I've completed a line test which hasn't detected any faults but I can see re connections on the line.
Chat Champion
Hi Debbie yes I have I’ve been having trouble since I first reported it. The lines never been good here but it’s never been this bad. 18mb down to 11mb is very noticeable.
Problem is I don’t know if it’s a broadband fault or line fault but something is causing disconnects constantly I have to say talk talks fault finding tests aren’t awful they never find anything anything.
Hi stokeash
If you have tested with a different router, filter and cable at the test socket then this will rule out any possible issues with internal wiring or equipment.
Would you like me to raise this over to our Network Team for investigation?
Chat Champion
Yes pleas Debbie.
I feel I have done all the testing and checking possible my end and I don’t have any internal wiring apart from the phone and router so it can only be some sort of network fault.
Thank you
Hi stokeash,
Have you tested with a different telephone or with the telephone disconnected, just to eliminate the telephone as a potential cause of interference?
Chat Champion
Hi, Yes I have had the phone disconnected altogether for hours and it’s still disconnecting.
SNR Margin: 7.5 dB / 12.3 dB
Line Attenuation: 6.1 dB / 26.8 dB
Output Power: 5.1 dbm / 5.2 dbm
Data Rate: 568 kbps / 9999 kbps
ES: 0 / 5
SES: 0 / 0
UAS: 217 / 217
FEC: 0 / 121129
CRC: 0 / 8
I’m now under the promised speed range as well for the broadband.
Chat Champion
Speed has gotten worse down to 8mb now which is basically adsl. I think I’m going to try changing isp unfortunately.
Chat Champion
Line State: up
Modulation: ITU G.993.2(VDSL2)
Annex Mode: ANNEX_B
DSL (Sync) Uptime: 1d:0h:4m:37s
UpLink / DownLink
SNR Margin: 7.8 dB / 12.7 dB
Line Attenuation: 6.2 dB / 26.8 dB
Output Power: 5.1 dbm / 5.1 dbm
Data Rate: 561 kbps / 8799 kbps
ES: 0 / 212
SES: 0 / 128
UAS: 46 / 46
FEC: 0 / 133035890
CRC: 0 / 5512
Chat Champion
Line State: up
Annex Mode: ANNEX_B
UpLink / DownLink
ES: 0 / 212
SES: 0 / 128
UAS: 46 / 46
FEC: 0 / 133035890
CRC: 0 / 5512
It’s pretty bad look at the errors now it’s unusable most the time
