disable the optimisation technology on my line
25 REPLIES 25
moonmoon
want to change the wifi channel
rang help, they said they would have the optimisation technology on my line turned off
over 2 weeks ago but it hasnt happened
can someone on here do it
Skynet_TX
Hi @moonmoon ,
Assuming you have the Sagemcom Wi-Fi hub then the staff here can turn that behaviour off for you.
For one of the TalkTalk staff on this forum to be able to look into this you will need to update your community profile to include your name, landline telephone number that your TalkTalk service is provided on & an alternative contact number. This will allow them to identify you, and they will then be able to help.
OCE_Chris
Hi moonmoon,
Can I ask why you want to have wifi optimisation switched off? We recommend leaving it on as it generally provides better wifi connectivity
moonmoon
the router auto chooses channel 6 which is really heavily congested with other users, i get lots of interference so need to change to a different channel.
chrisg4kvi
Same here. Its not exactly intelligent when it puts every Talk Talk router on the same channel. Why can't Auto be Auto, and manual be manual??
OCE_Chris
OK moonmoon, I'll take a look at this now and get back to you when I've disabled it
OCE_Chris
Hi chrisg4kvi,
If you need assistance can you start your own thread (if you haven't already) and we'll be happy to help
OCE_Chris
Hi moonmoon,
I'm unable to communicate with your router at the moment, could you switch it off and leave it off for at least 30 minutes then switch back on. Could you let me know when you've done this and I'll have another go
moonmoon
been out but my router is on now
OCE_Chris
Hi moonmoon,
I've disabled wifi optimisation as requested
moonmoon
no you havent its still reverting back to channel 6
OCE_Chris
I've checked and it's definitely switched off, could you try changing the channel again please
chrisg4kvi
I think there is some confusion. There were two of us asking the question and mine currently seems to be OK.
OCE_Chris
I've checked again and moonmoon's if definitely switched off.
moonmoon
still reverting to 6
OCE_Chris
OK thanks, is your router currently switched on, I can't communicate with it again?
moonmoon
its on now
OCE_Debbie
Hi moonmoon
Do you switch your router off over night?
moonmoon
yes i do
only use it for a few hours in the morning
like now
OCE_Debbie
Hi moonmoon
For fibre connections we advise leaving the router switched on. If the router is switched off and on often then this can affect the sync speed.
The Wifi optimisation has been switched off.
