download speeds
chrishb
I'm getting over 65Mbps on my desktop PC which is hard wired to the router but only 23Mbps via wi fi. Any help would be appreciated. The wifi speed is about the same on both my laptop and Samsung tablet.
Skynet_TX
Hi @chrishb,
There are a few things you could try to see if it is Wi-Fi interference causing the problems.
Split the SSID's on the router, this will allow you to give the 2.4GHz and 5GHz network bands different names, so your Wi-Fi devices will then see those two networks separately, you can then try connecting to one or the other to see if one gives a more reliable connection than the other. Doing this in itself won’t fix the problem, but it makes it easier to troubleshoot as you can easily see what device is using what band.
Change the channels that your router broadcasts the Wi-Fi signal on, you can use free smartphone Apps like this to see what channels are being used within range of your smartphone, you can then change your router to use channels that are less congested.
If trying the above makes no difference then it may indicate an issue with the router, the staff here would be able to help with that.
The staff here won't be around now until Monday, but they should be able to respond to this post early next week to help.
OCE_Michelle
Hi chris,
How are you getting on?
