dyndns disappeared
7 REPLIES 7
MY option for dyndns has suddenly gone. Can anyone help me please?
What make/model of router are you using & what firmware is it running?
Hi Keith, This has been sorted now but still struggling with port forwarding for my cctv. If you have any answers to this I would really appreciate it. Thanks
Please supply as much detail as possible.
Hi Keith,
since changing to TALKTALK i have lost access to viewing my CCTV when away from home. i have set up port forwarding as per instructed by the company that installed the cameras but unfortunately i cannot still view them when away. my router is TALKTALK wif-fi hub sagemcom version FAST 5364-3.
the port the DVR needs is 34567 and i have set up a dyndns and added it to the router. none of this has made any difference
Is this a TCP or a UDP port? Have you set up a DHCP Reserved IP address on the router for your DVR or a statically configured IP address on the DVR itself that is outside of the DHCP address pool range?
Please send me a screenshot of the forwarding that you have currently setup & I will advise.
Hi Keith, I have now sorted it out. I just manually specified the DNS to match the router ones and it worked. Thank you for replying to me.
Hi sukhi,
Glad to hear that you've managed to resolved the issue 🙂
