faster fibre speed ( up, down.up down, up down.
greg55
first of all i always work wireless.
managed to get up to 27meg download.
now back down to 17- 18meg.
i dont care what i get at my router, the speed that counts is my actual speed i get at my laptop.
all i use is one laptop
why can't my speed be kept stable at 27meg.
i have switched off the router, i have changed router channels as suggested by O.C.E.'S.
when i run speed tests, they range from 15-22meg.
up & down all the time.
it is strange that my monthly bill for faster fibre to talktalk doesn't fluctuate.
if my set up is capable of receiving 27meg wireless, then why is this not kept stable.
when i switched to fibre i was told it was being monitored for 14 days until it stabilised.
that was over a month ago.
what is going on.
If you have the HG633, HG635, DSL-3782 or the TalkTalk Wi-Fi hub, they are dual-band routers & offer both the older 2.4GHz & the newer 5GHz Wi-Fi bands. The problem is these are two different networks (SSIDs), but they share the same name, so you can't tell which one you are connected to. Log into the router (http://192.168.1.1) and enter a username of "admin" and if the HG635 a password of "admin" as well, or if the HG633, DSL-3782 or the TalkTalk Wi-Fi hub, use the unique router password (see the label on the rear of the router at the top).
HG633/635 go to:-
"Customise my wireless network"
Append "5G" to the end of the network name of the "Wireless 5 GHz SSID" field. Then click "Save".
DSL-3782 go to:-
Settings > Wireless (Wi-Fi)
Append "5G" to the end of the network name of the 5 GHz "SSID" field. Then click "Save".
TalkTalk Wi-Fi hub
Go to:-
Dashboard > See Wi-Fi Settings > Manage Advanced Settings > Wi-Fi 5Ghz gear icon > Basic
Append "5G" to the end of the network name of the "SSID" field. Then click "Apply".
This will not fix your issues, but it will make it much easier to identify the band you are connected to. This way you will know which band is causing your problems.
Having said that, there is another approach which can be better, which is to use Band Steering. This will automatically move any 5G compatible device connected to the 2.4G band to the 5GHz band. This is available on the HG633 (V2.00), DSL-3782 (V1.10) and the TalkTalk Home Hub. To use this, leave both network names identical on each of these routers and on the HG633 you will need to additionally enable Band Steering from the initial Wi-Fi menu.
You may then wonder what was really the point of this if it won't solve the problem? This is because the whole topic is too complex to be dealt with in one post. The next stage involves sending out a guide to you to help you get me some important diagnostic results, so as I can analyse them for you and recommend changes to your router configuration to solve them.
Windows 10 1903 intermittent WiFi issues
With the May 2019 feature update to Windows 10, some older computers may experience loss of Wi-Fi connectivity due to an outdated Qualcomm driver. Please see this from Microsoft:-
https://docs.microsoft.com/en-gb/windows/release-information/status-windows-10-1903#445msgdesc
Hi greg55,
Our line management system (DLM) has moved you to a faster profile, your router is now in sync at 40Mbps, have you noticed any improvement in your throughput speeds?
Have you checked out Keith's suggestions?
