gone from 65mb to 30mb down last week or so.
still capped at 35mb constant.
absolutely no change as you can see
Hi JohannaSwe
Apologies for the delay.
Your line is now showing in sync at 57.1mb. What speed are you now receiving when running speed tests?
Hi there. yes, there has now been an improvement and tests are showing between 47 and 52mbps down. this is still far lower than my guarenteed minimum. what else can we do to get the speeds up?
Hi JohannaSwe,
As DLM has now moved you to a faster profile I suggest we should give it a couple more days to see if DLM improved your speed further. Can you bump the thread on Friday and we'll see how you're getting on
will do cheers Chris
Hi JohannaSwe,
Great, thanks 🙂
Hello. I’m bumping this thread again as I’m again having the same issue as previously stated here. My download speed has sunk again to around 20mbps. Nothing on my end has changed. Could you guys take a look at this again for me?
Hi JohannaSwe,
I'm sorry for the delay and I'll take a look now. I've run a test on the line which hasn't detected a fault. Could you try switching the router off for a full 30 minutes and then retest the speed again please to see if their is any improvement?
