internet connection probmes
7 REPLIES 7
I'm having intermittent problems for last few days with my internet connection. Router has white light on, I've done a test connection and that shows fine. I turned it off last night for a good few hours and when i put it back on it just kept flashing amber.
On my phone it WIFI shows connected but no internet access. Its slow and hardly works, even with devices that are hard wired.
Please help
thanks
Hi calypso18
I've updated your router firmware version, please can you let us know how the connection compares following this?
Sorry for late reply, It seems better then what it is was much more responsive.
Hopefully problem resolved
thank you for your assistance
Hi calypso18
Debbie 🙂
I'm still experiencing problems I'm unable to get on the internet stating same as before? Please help
Hi calypso18
I've completed a further line test which has now detected a possible fault on the line so I have escalated this straight over to Openreach to be investigated by a line engineer.
We should receive further updates within the next 48hrs.
Engineer came over yesterday afternoon found a fault and then it seemed to have cleared. At the moment it seems fine any issues I will let you know.
Thank you for your help
Hi calypso18
That's great 🙂 Please let us know if you do experience any further issues.
