internet disconnecting few minutes after starting online game. Scam protection or something?
10 REPLIES 10
I regularly participate in online gliding competitions. In last couple of days I got disconnected shortly after starting online flight (game). Internet LED on my router goes off, and then it reconnects shortly after, usually in less than a minute. If I connect to the game again situation repeats itself. If I am not connected to the server created by the game (condor soaring simulator 2) I have no problems with the connection.
Is there some sort of security or protection that thinks that I am under cyber attack or that I am attacking someone which could cause my disconnections?
The situation is really annoying as flying virtual gliders is a big part of my online activity. below is a log from today. I was connected all day with no problems. Few minutes after starting online race I got disconnected. After joining server again I got disconnected again.
3/31/2020 8:05:15 PMOnline
03/31/2020 8:05:12 PMNo internet connection
03/31/2020 8:05:12 PMInternet connection issues
03/31/2020 8:04:55 PMNo internet connection
03/31/2020 8:04:51 PMInternet connection issues
03/31/2020 8:04:43 PMNo internet connection
03/31/2020 8:04:33 PMInternet connection issues
03/31/2020 8:04:27 PMNo internet connection
03/31/2020 8:04:24 PMOnline
03/31/2020 8:04:03 PMInternet connection issues
03/31/2020 8:03:55 PMNo internet connection
03/31/2020 7:57:48 PMOnline
03/31/2020 7:57:35 PMNo internet connection
03/31/2020 7:57:30 PMInternet connection issues
03/31/2020 7:57:14 PMNo internet connection
03/31/2020 7:57:09 PMInternet connection issues
03/31/2020 7:57:03 PMNo internet connection
03/31/2020 7:57:00 PMInternet connection issues
03/31/2020 7:56:57 PMNo internet connection
03/31/2020 7:56:54 PMInternet connection issues
03/31/2020 7:56:46 PMNo internet connection
03/31/2020 7:56:43 PMOnline
03/31/2020 7:56:21 PMInternet connection issues
03/31/2020 7:56:15 PMNo internet connection
TalkTalk Content Team - TT Staff
Hi @witor I have passed this onto the team to pick up for you ASAP. Before we can look into your account please can you add your home phone number to your Community Profile so we can locate your details. Please do not post any personal info on here as it’s public. We're working through a large queue with a reduced support team at the moment so we really appreciate your patience 🙂 thanks!
Any chance of someone looking into this issue? My initial post was 9 days ago. Today I tried  to use my simulator again and as before was disconnected from the internet few minutes after entering online session....
Hi witor
I'm really sorry for the delay.
I've completed a line test which hasn't detected any faults. There were re connections showing on the line but the connection appears to have remained stable since 13/04.
Are you still experiencing this fault?
Yes, I am still experiencing short disconnections quite frequently.
My setup and hardware has not changed. Everything is connected excactly the same way it was connected before disconnections started. If there is no problem with my line the only other reason I can think of is that my router has developed a fault.
Hi witor,
Apologies for the delay, is the connection still dropping? Line test is showing 6 disconnections on the 27th but only a couple of other disconnection over the last 2 weeks
I am still getting disconnected quite often. My connection used to be rock solid, but it is not anymore. Nothink has changed in terms of cable connections or hardware, so if my line is fine the only other think I can think of would be my router beginning to malfunction.
Datetime Status
04/29/2020 2:05:31 PMOnline
04/29/2020 2:05:21 PMInternet connection issues
04/28/2020 10:03:32 AMOnline
04/28/2020 10:03:23 AMInternet connection issues
04/28/2020 12:59:48 AMOnline
04/28/2020 12:58:34 AMNo internet connection
04/28/2020 12:58:30 AMInternet connection issues
04/28/2020 12:58:28 AMNo internet connection
04/28/2020 12:57:54 AMInternet connection issues
04/27/2020 8:54:40 PMOnline
04/27/2020 8:54:33 PMInternet connection issues
04/27/2020 9:12:09 AMOnline
04/27/2020 9:12:00 AMNo internet connection
04/27/2020 9:12:00 AMInternet connection issues
04/27/2020 9:11:38 AMNo internet connection
04/27/2020 12:47:23 AMOnline
04/27/2020 12:46:57 AMInternet connection issues
04/24/2020 5:41:52 PMOnline
04/24/2020 5:41:36 PMInternet connection issues
04/24/2020 2:47:33 AMOnline
Hi witor,
Sorry for the delayed reply, we're doing our best in these unprecedented circumstances due to the Corona virus to answer everyone as quickly as possible.
I've run a test on the line which hasn't detected a fault and the connection looks stable for the last 6 days. How have you found the stability since your last post? Are you connected wireless?
I am connected with a lan cable to the router. Connection was not bad in the last couple of days, but not as solid as before.  Most recent record of my disconnections:
Datetime Status
04/30/2020 10:56:11 AMOnline
04/30/2020 10:56:05 AMInternet connection issues
Hey witor,
Sorry for the delayed reply, we're doing our best in these unprecedented circumstances due to the Corona virus to answer everyone as quickly as possible. I have tested the line again and can see there is an issue with your wiring coming into the premises. This will cause errors and drops. We will need to get an Openreach engineer to look at and resolve this.
The next step will be to arrange an engineer visit to investigate further, to do this can you confirm:
To confirm you're the account holder can you reply to me via PM (Personal Message) with the following information:
  • Full Name
  • Home telephone number or account number
  • Are you the account holder
  • 1st and 3rd characters of your telephone password
    NOTE: If you don’t have a telephone password why not add one now check out Setting up your telephone password for details
    If password is unknown, confirm the below:
  • Your registered email address:
  • Your registered mobile phone number:
Note: Please do not post personal information directly in the Forums.
Thanks and keep safe
Jon
