modem mode?
3 REPLIES 3
I am getting talk talk as the second backup line to the house. Im currently using a virgin hub in modem mode which plugs into my UDM pro.
Im getting the engineer to come on the 12th. Will i get the setup with the modem ? and the hub seperate (this would be ideal as i dont need the router)
I opted for the 80mbps speed option.
No.
You will have the TT HUB, a combined modem/router that will connect to the incoming phone line.
It cannot be set to work in modem-only mode.
Martin
You can try any third-party VDSL modem or modem/router, that page just gives you the settings.
You'll have to do a bit of research to find devices that are both compatible and supports all the modes you require.
Martin
