my wifi keeps dropping out
9 REPLIES 9
every ten minutes or so my wifi signal drops done all the usual called so called techs did all the usual replaced all cables bought the up to date new hub is dropping on all devices in house have to keep turning router off been with talktalk 3 years contract up in 2 months then im leaving its like banging your head against a brick wall phoning them
s gray
The TalkTalk Wi-Fi Hub is a dual-band router & offers both the older 2.4GHz & the newer 5GHz Wi-Fi bands. The problem is these are two different networks (SSIDs), but they share the same name, so you can't tell which one you are connected to. Log into the router (http://192.168.1.1) and enter a username of "admin" and use the unique router password (see the label on the rear of the router at the top).
Go to:-
Dashboard > See Wi-Fi Settings > Manage Advanced Settings > Wi-Fi 5Ghz gear icon > Basic
Append "5G" to the end of the network name of the "SSID" field. Then click "Apply".
This will not fix your issues, but it will make it much easier to identify the band you are connected to. This way you will know which band is causing your problems.
Having said that, there is another approach which can be better, which is to use Band Steering. This will automatically move any 5G compatible device connected to the 2.4G band to the 5GHz band. To use this facility on the Wi-Fi Hub, leave both network names identical.
You may then wonder what was really the point of this if it won't solve the problem? This is because the whole topic is too complex to be dealt with in one post. The next stage involves sending out a guide to you to help you get me some important diagnostic results, so as I can analyse them for you and recommend changes to your router configuration to solve them.
hi thanks for reply tried this im on 2.4 phoned talktalk again same rubbish from them going to change to virgin thanks again
s gray
Hi Steven
Did this fault occur with 2 different routers?
If you read my post I did say that this alone fixes nothing. The next stage of my help can normally fix these issues, it is too involved to all be in one post.
If you want my help, all you have to do is ask!
yes could i have your help please that would be great
s gray
Please see my attached guide on Wi-Fi interference & initially look at the section called "Are you suffering from interference – prove it first". This section includes full details of Wi-Fi analysers that I recommend for Windows, Windows phone, Android and Apple operating systems. However, I have no way of testing the Apple product. Do not worry about interpreting the results, I will do that for you.
Please post the screenshots that I have requested in my guide (no photos please they can be difficult to read as text can get out of focus when zoomed), from the analyser you are using (also in my attached guide). Please ensure that the analyser window is maximised (if Windows) before taking the screenshots & upload them via the "Insert Photos" button on the post editor's toolbar as large images. If they are too small, I will not be able to read them & although I can enlarge them, this just puts the text out of focus. If you prefer PM them to me. If you do PM me, then please add a link in there to this thread, so as I can find it easily.
s gray
s gray
What about the other views I requested? Please can you also include:-
2.4GHz channels (with your 2.4GHz SSID (network name) selected
5GHz channels (with your 5GHz SSID (network name) selected
