poor fibre broadband speed
Joseph3241
Hi Chris!
If by "noise" you mean hisses, pops or crackles then the answer is no although it is sometimes hard to hear a caller as the volume is low. To be honest, we don't use the landline for outgoing calls as we both have mobile phones and calls are included in the sim package and are also a whole lot clearer. Might be worth TalkTalk checking the phone line though?
I've now disconnected the router from the test socket.
Cheers,
Joe
OK thanks Joe. Can you bump the thread tomorrow and we'll check for updates from our network team
Joseph3241
Hi Joseph3241,
There are no updates yet so I'm chasing this up with our network team. If you don't hear anything later today or over the weekend can you bump the thread on Monday and we'll check again for updates
Hi Joseph3241,
Our network team have advised that the next step will be to arrange an engineer visit to investigate further, to do this can you confirm:
Joseph3241
Hi Chris!
Thanks for this. Let me think about it for a couple of days - I'm concerned that my wiring goes under the carpets and don't want to incur high charges if possible.
Joe
Hi Joseph3241,
We've received a further update from our network team, it's now been logged out as a non-appointed task, we should receive an update within 72 hours so if you don't hear anything beforehand can you bump the thread on Monday and we'll check for update
Joseph3241
Hi Joseph3241,
I'll chase this with our network team and let you know when I receive an update
Hi Joseph3241,
Our network team say the fault has been cleared and closed by Openreach - is your router currently switched on and connected to your telephone socket?
Joseph3241
Hi Chris!
My router is definitely switched on and plugged in. That's how I bumped the thread earlier and sent you a clip of my current speeds.
J
OK thanks, could you another speed test please as your sync speed is now 38Mbps
Joseph3241
I wish I could report 38 Mbps............back to square one!
J
Hi Joe
Please can you power down your router for a full 30 minutes and then run another speed test following this?
Joseph3241
MARVELOUS!
I can't thank you and your team enough! You've all been so helpful!
Do you know where the problem was in case it should happen again?
Best wishes.
Joe
Hi Joe
Thanks for keeping updated. Work was completed on the line by BT Openreach to resolve this fault.
